mf 135-hydraulic problem and year
hwyman100953
11-27-2006 03:54:19
first tractor ever bought.its a mf 135.on the front bucket ,the lift and lower work great,the tilt will go all the way down,but will only tilt back up only a couple inches,the bucket is pointing straight down to the ground,and wont tilt back up.disconeected hydraulic lines to both tilt cylinder has enormous amount of pressure.removed both hydraulic lines to each cylinder,tried to compress both cylinders,one wont contract at all,the other did about half way.called mf dealers they just say bring it to them for repair,live in stoneville nc,and closest dealer is about 70 miles.all other hydraulics seem to work fine.any help yall can give me id appreciate.also cant figure out what year it is.the plate on dash beside steering wheel says 135-451-492-M.its the only thing i can find checked all over.thanks yall for any help yall can give me.dave
tldnc
11-28-2006 16:53:57
 Re: mf 135-hydraulic problem and year in reply to hwyman100953, 11-27-2006 03:54:19
There is a Massey Ferguson dealer about 20 miles from Stoneville, N.C. It is Collins Tractor Co.,3610 Moorefield Store Rd.,Stuart Va. ph(276)694-6161. It is just over the NC/Va. state line west of Sandy Ridge, N.C.
JJ. in B.C.
11-27-2006 13:50:59
Dave, if that is indeed the serial # it could possibly be a 1975 UK model.
JJ.
135 fan
11-27-2006 08:16:44
I think the problem is with the cylinders and not the pump. You'll have to take them apart to see what's wrong. The seals could need replacing on the piston or cap. It's unlikely but I've seen broken rods on cylinders or the nut come off that holds the piston to the shaft. The seals wore out on my bobcat and although the bucket would tilt back, it fell down almost as fast. Put new seals in and problem solved. Hope this helps. Dave
DavidP, South Wales
11-27-2006 07:27:33
Hi Dave,
Have you looked at the bucket ram to see if it is bent or damaged? If it is going to the end of its travel the tube or seal head may be damaged or loose. It's possible that at full stretch there is little support and may jam if there is wear in the cap.
Let me know
DavidP, South Wales
