MF50 Plow Question
LarryDM
11-26-2006 14:45:39
Hi all,
Can anyone tell me how much plow the MF50 can pull? Thanks.
MF Poor
11-27-2006 13:16:16
 Re: MF50 Plow Question in reply to LarryDM, 11-26-2006 14:45:39
Gas or diesel? I"ve owned one of each. The gasser would pull 2X14""s, but did better with 2X12""s in our clay soil. The diesel would pull 2X14""s without any effort whatsoever. Gasser would turn the gas tank inside out while the diesel would go on like the Energizer Bunny on a tankfull.
Lou
11-27-2006 07:13:17
There are too many variables to list, but why not start with a 2x12 or 2x14 and take it easy on the old girl.
Boss Hog
11-27-2006 06:13:50
As someone already said, it's basically the same HP as a 35.
With my MF 35, I've pulled a 3-12 plow and a 3-14 plow.
The 3-12 plow is about perfect. I go in first gear in high range in most conditions.
The 3-14 plow was a bit much. I had to run in 3rd gear in low range, and it worked the thing really hard. I wouldn't recommend it.
I saw someone else use a 2-16 plow on a TO-35, and it worked real slick. The wider bottoms turned and covered well.
CENTAUR
11-26-2006 16:58:14
Larry,Are you talking about a 3 pt. If so I would think it would pull the same as a mf35 or mf135 since is the same engine,trans & rear end. CENTAUR
supergrumpy
11-26-2006 15:13:59
if I remember, the 50 is somewhat similar to my 135
with no weight in the tires, sandy clay soil plows fine with single bottom, old sod full of rocks barely makes it, problem is wheel spin not power
loaded tires would easily pull 2 bottoms in turned soil but don't think it would work in sod
steveormary
11-26-2006 15:04:59
Larry; Depends on your plowing conditions. 2-14"s or 2-16"s. Might pull 3-14"s. Like I say,depends on soil conditions.
steveormary
LarryDM
11-26-2006 15:32:40
 Re: MF50 Plow Question in reply to steveormary, 11-26-2006 15:04:59
Use would be a mix of sod and corn/bean ground (food plots). The tires are filled. Hoping for 2 16's as they are fairly easy to find.
Thanks.
supergrumpy
11-27-2006 07:54:44
 Re: MF50 Plow Question in reply to LarryDM, 11-26-2006 15:32:40
try the double plow, can always take the back share off if it won"t pull with 2 on
breaking that sod is hard work and clay soil really drags you down
stick with a good used plow you can get parts for, will need points and slides sooner or later
next you need a set of good heavy discs
