tea 20 pivet point
steve32
11-26-2006 00:37:44
Im haveing trouble removing the pivet post that extenteds from the rear axle houseing this is the pivet for the 3 point lingage.Need to resize this to much slop in it. Is it bolted on inside or screwed into axle assembly? Might just bush it up a tad.
DavidP, South Wales
11-26-2006 01:54:32
 Re: tea 20 pivet point in reply to steve32, 11-26-2006 00:37:44
Hi,
The pin is held on a taper with a nut inside. If you are replacing one or both you will need to remove at least one axle housing. Look for wear in the ball at the end of the lift arm as well.
DavidP
