oem auxiliary control valve
Curtis E.
11-25-2006 06:17:14
My 175 has factory auxiliary hydraulics with the control valve being fed by the auxiliary pump mounted on the front of the main pump. My problem is that the control valve is leaking internally on one spool. This valve is a 2 spool valve controling 2 sets of remotes. One spool works fine and will develope rated pressure on test gauge (2500 psi). The other side will only develope about 1000 psi. This is an oem valve and would like to keep it that way as the tractor is all original. Any one ever had this problem and any tips to fix. My parts book does not list a # for new spool. Are these valves still available from Massey? Thanks Curt
