massey 135 diesel
I goofed up
11-25-2006 02:19:53
had to replace an o ring inside the fuel injector pump and like a dummy I forgot to pay attention to which hole the throttle shaft spring hooked to for the governor control. Inside are 3 holes that all this goes to if I remember correctly. I have it in the middle hole and and the engine dont rev up to full throttle.
Would anybody know which hole to shoot for to make it rev higher? The one to the front or to the rear?
Thanks ....stupid
JJ. in B.C.
11-25-2006 11:12:48
 Re: massey 135 diesel in reply to I goofed up, 11-25-2006 02:19:53
Fortunatly i have never had this problem, but i remember someone posting awhile ago that if you go to your dealer or good pump shop armed with ALL the numbers off your pump they are able to tell you the correct positioning. Hopefully someone else can shed more light on this.
JJ.
