Massey Ferguson Super 90 radiator hose
Trenton Boomgar
11-24-2006 18:40:44
Does anyone happen to know where I can find a new radiator hose for my Super 90 that I'm currently in the process of restoring? The way that it is set up the hose needs to be able to bend at a 90 degree angle without cracking otherwise it will not work. I have searched many places but have not had any luck yet, I would appreciate your help. Thanks!
Fred in NY
12-04-2006 17:16:21
 Re: Massey Ferguson Super 90 radiator hose in reply to Trenton Boomgarden, 11-24-2006 18:40:44
My local NAPA store supplied me with a #8484 hose and after cutting it to length, it worked perfectly. If you do a neat job cutting, it will look original.
JohnMB
11-27-2006 20:49:17
Perkins 302 engine hoses etc.
Upper straight hose of correct dia.
Lower Gates molded 21794 cut to fit
Bypass Gates molded 20267 cut to fit
Fan and Gen belt Gates 9510
No I have no conn to Gates but I used these on my 1963 and they worked very well.
mn.Chuck
11-25-2006 10:46:23
Trenton, You don't say if it is gas or diesel.
The Depot,an indepen. co.handling OEM parts has
the lower hose for either. If it is the curved
inlet hose on the diesel, they do not have. Let
me know if you still need to send further instructions. Chuck
135 Fan
11-24-2006 19:01:31
Can you use a ribbed hose that is designed for bending without kinking? They usually have a spring in them as well. Dave
