Massey Ferguson 65
JonasLee
11-24-2006 10:57:46
Someone told me that you can find out special info about a tractor by using the casting numbers. I was wondering if anyone had any info regarding Block # C37112210U; Head # 22 11 J, 37116410, and RMC 23059A All replies would be greatly appreciated. I would also like to know the torque specs for head bolts, main bolts, and rods. Thank You.
Aaron Ford
11-24-2006 18:07:05
 Re: Massey Ferguson 65 in reply to JonasLee, 11-24-2006 10:57:46
I failed to find any reference to those part numbers in my mf65 parts manual. I am assuming it is a Perkins but I cannot find anything in that book either... There are part numbers that come close to yours, but none exact.
If you supply the engine type or serial numer I will look up the torque values.
HTH Aaron
Jack in NB
11-25-2006 04:46:14
 Re: Massey Ferguson 65 in reply to Aaron Ford, 11-24-2006 18:07:05
The numbers are consistent with the Perkins numbering system, but they do not appear in my books for the A4 203 or the later AD4 203.
It could be a 192 engine - some UK 65's were fitted with that model.
Can you find an engine serial number? On the 203's it's stamped into the flat surface at the top of the block, back, left (injector pump) side.
JonasLee
11-28-2006 07:07:04
 Re: Massey Ferguson 65 in reply to Jack in NB, 11-25-2006 04:46:14
I found the serial numbers 2950302.
