165 trans fluid
JAT
11-23-2006 19:00:54
The transmission fluid on my 165 is low so today I went to buy some only to realize I have no idea what it takes. Is it gear oil, hydraulic fluid, transmission fluid or what?
Don-Wi
11-25-2006 10:08:38
 Re: 165 trans fluid in reply to JAT, 11-23-2006 19:00:54
If you've got a Massey dealer in the area, go to them. They call for MF Perma-tran III. Otherwise, if the oil at the store says it meets MF's specs, it should be fine. It's a hydraulic oil that doubles as a transmission oil, so just straight Hyd. oil isn't good enough.
Donovan from Wisconsin
JJ. in B.C.
11-23-2006 19:40:53
MF recommends using trans/hydr oil meeting M- 1129 specifications.
JJ.
JAT
11-24-2006 14:28:27
 Re: 165 trans fluid in reply to JJ. in B.C., 11-23-2006 19:40:53
What does that mean? Does it state that on the label? Thanks
JJ. in B.C.
11-24-2006 16:03:42
 Re: 165 trans fluid in reply to JAT, 11-24-2006 14:28:27
Yes it should do.
JJ.
