Broken Starter Mounting Flange
Oliverjag
11-23-2006 18:08:20
Two of the starter mounting tabs on my Pacer are broken off. The starter cone appears to be cast iron. Has anyone welded these and what type of rod should be used? Any help is appreciated.
jerrycpp (WA)
11-23-2006 21:35:59
 Re: Broken Starter Mounting Flange in reply to Oliverjag, 11-23-2006 18:08:20
To weld cast iron, use nickel rod. After it is all perfectly clean and you've chamfered the edges of the break, and have everything clamped in place, heat the whole thing, using a rosebud torch to get the area you're going to weld nearly red hot. Weld it with nickel rod. As it cools SLOWLY, use the pointy end of your slag hammer to peck along the weld and the surrounding area for a minute or two. The pecking will help align the molecules. COOL IT SLOWLY. If you have some fly ash, put it in there and let it take an hour or so to cool. You can also wrap it in fibreglass insulation. You'll be amazed at what a great welder you are!
oliverjag
11-24-2006 05:23:40
 Re: Broken Starter Mounting Flange in reply to jerrycpp (WA), 11-23-2006 21:35:59
Thanks for the help.
