What kind of oil in Perkins A.318 4 cyl diesel?
Dale Brown
11-23-2006 17:06:09
I live in an area that can get well below freezing and as hot as 100F. What would be a good grade of motor oil that I could use year round?The manual only mentions straight weight oils. What about multi-viscosity? tractor supply seems to push the 15W40. Any suggestions?
thanks, Dale
Don-Wi
11-25-2006 10:14:19
 Re: What kind of oil in Perkins A.318 4 cyl diesel in reply to Dale Brown, 11-23-2006 17:06:09
We run 15w-40 in everything, don't waste your money on synthetics unless you put 3-500 hours on every year.
Donovan from Wisconsin
BTW- Is it a 285 or 1085? we've got a 285 and it's got 6100 on the original 318. When we get the oil filters from the dealer, they don't even stock the "standard" short filter for the 4 cyl, perkins, they just give us one for the larger 6 cyl. that are a bit taller. This is a big time dealer too with great parts support.
135 Fan
11-23-2006 17:27:20
15-40 is OK if you always have the tractor plugged in. Otherwise a thinner oil would be better for starting. 0w40 synthetic is claimed to be for year round use but is pricey. I had some in my bobcat last year and noticed that it started a lot easier and spun faster in the cold. I think there is also 5w40 semi-sythetic. Dave
JJ. in B.C.
11-23-2006 17:26:56
Hi Dale, i use 15w40 in my AD3 152 in similar weather conditions as yourself with no problems.
JJ.
BIGmarv1085
11-24-2006 20:21:12
 Re: What kind of oil in Perkins A.318 4 cyl diesel in reply to JJ. in B.C., 11-23-2006 17:26:56
I run rotella 15w40 year round.
Dale Brown
11-25-2006 18:34:54
 Re: What kind of oil in Perkins A.318 4 cyl diesel in reply to BIGmarv1085, 11-24-2006 20:21:12
Looks like 15W40 wins the vote. I was considering using it, I just wanted to check to see what other peoples experience with it was....Thanks.
B.T.W. it is a 1085 with 3600 hours on it.
Dale
