MF-35 Perkins Radiator Support Rod
Dean
11-22-2006 04:53:51
Upon removing the radiator from my MF-35 Deluxe with Perkins diesel engine I discovered that the radiator support rod between the radiator tank bracket and the thermostat housing is missing.
Anyone have a spare that they would like to sell?
Thanks, in advance.
Dean
va. rebel
11-22-2006 05:22:42
 Re: MF-35 Perkins Radiator Support Rod in reply to Dean, 11-22-2006 04:53:51
very easy to make one
Dean
11-22-2006 13:49:24
 Re: MF-35 Perkins Radiator Support Rod in reply to va. rebel, 11-22-2006 05:22:42
Rebel:
Yes, of course, and I will do so if necessary.
I value my time highly and would prefer to buy one if possible.
Thanks for the advice.
Dean
DavidP, South Wales
11-22-2006 08:24:07
Hi,
All you need is about 12 inches of 5/16" rod. Drill a hole for a split pin at one end and bend it at 90 degrees about 1/2" from the end. Measure the distance between the radiator and support, bend drill and cut. Remember to bend the ends at 90 degrees apart. Job done.
Dean
11-22-2006 13:47:11
 Re: MF-35 Perkins Radiator Support Rod in reply to DavidP, South Wales, 11-22-2006 08:24:07
Thanks, David.
If I cannot find a used one I will make my own. Fortunately, in addition to the 35 Deluxe, I have a FE-35 with Perkins, and I plan to remove the hood next week to work on the radiator and injectors. I will use your measurements and the FE-35 rod to make one if necessary.
Dean
