MF 165 Clutch
Paul Smith
08-23-2000 01:59:48
I have a multi-power MF165 that wears out the splines on the PTO clutch plate and the shaft that goes into it in just 200 hours. The clutch adjustments are set evenly and the impliments being driven are set up properly and give no problems on other tractors.The hydraulic pump tests out okay. We have gone through three clutch plates and two shafts in the last 600 hours but cannot find the fault.Has anyone ever heard of this problem or have any suggestions as to it's cause. please pass this request for help on if you cannot assist.Thank you,Paul Smith.
Bill
08-24-2000 07:31:12
 Re: MF 165 Clutch in reply to Paul Smith, 08-23-2000 01:59:48
Hi, Have a used 165 I just bought apart for the same problem. If you have independent PTO and you engage it with RPM's other than idle , you are going to tear up the pressure plate and spline. If you have live PTO which works off the 2Nd clutch disk I don't know. If I can be of help e mail me. Bill
