Fuel gauge
Dave Sulz
08-22-2000 20:57:55
The fuel gauge on my 1100 MF quite working. Which is the most likely culprit, sender or gauge? I don't want to change both if I don't have to. Dave (Alberta, Can.)
Charlie
03-30-2002 18:17:33
 Re: Fuel gauge in reply to Dave Sulz, 08-22-2000 20:57:55
With the tractor running check to see that you get 12VDC on one side of gauge. If no 12VDC the check wiring and the oil pressure switch. I just brought a sending unit for $35 at MF dealer.
lee
08-23-2000 19:30:13
make shure the tank is grounded to the frame, and also remove the sender and see if the float fell off or sinks in the fuel. also to check the gage ground the lead on the sender, the gage should go to full if it doesent the gage may be bad. good luck.
