Pony engine crankshaft thrust washers
ENJ62
11-20-2006 10:08:30
When disassembling our Pony we didn't keep track of how the bronze thrust washers mount. Both washers have one face with grooves for lubrication. How do these mount ? Groove faces in or out on the main bearing or is one out and one in ?
Thanks ED
mn.Chuck
11-21-2006 08:15:21
 Re: Pony engine crankshaft thrust washers in reply to ENJ62, 11-20-2006 10:08:30
Hi Ed, Thought someone with experience would jump
in. In my Pony service manual The shims go on first,then the bronze washer with the beveled side
towards engine and flat side w/grooves outward.
Then the heavy step plate with the flat side
inward and step collar outward. The parts book
also shows the grooves outward so I am confident
in that. End play should be .0025-.0080. Shims
come in .002-.008. Pry crankshaft back as far as
possible then measure w/ feeler guage or dial ind.
Good luck, Chuck
ENJ62
11-22-2006 11:58:31
 Re: Pony engine crankshaft thrust washers in reply to mn.Chuck, 11-21-2006 08:15:21
Thanks , for the information Chuck. I also was wondering what service and parts manual you are using? Are they reprints? I have an copy ofthe MH service manual for the 1954 model pony but it lacks alot of detail.
Ed
mn.Chuck
11-22-2006 12:36:26
 Re: Pony engine crankshaft thrust washers in reply to ENJ62, 11-22-2006 11:58:31
Ed, The service manual is PONY tractor, Service
manual,Ferguson Service, Form #690427m1 3M-8-54
This was thru the Ferguson distribution but may be
the same. Parts book dated 6-54 and has newer yr.
updates in it. It is by Massey Ferguson. The detail in service was not the greatest. In the era
of those tractors I never felt the manuals were good enough. Chuck
ENJ62
11-23-2006 09:10:01
 Re: Pony engine crankshaft thrust washers in reply to mn.Chuck, 11-22-2006 12:36:26
Chuck , I called Jen Sales to see about their parts manual for my tractor a while back. They checked and didnt know what year the reprint came from. So I've been holding off on getting it. Its pricey and it may not suit the changes to the 1954 model.would you know any source for a copy of the 1954 parts manual .
ED
