MF65
Leon R
11-19-2006 08:08:43
There is a mf65 with loader and backhoe for sale in my neck of the woods. It was a Canadian military unit and looks like an industrial model. Was there anything different about the military units? Would this be a good machine or too light of a tractor.
Aaron Ford
11-20-2006 11:14:24
 Re: MF65 in reply to Leon R, 11-19-2006 08:08:43
The 65 is a solid built tractor. The industrial models, even more so. The utility models were 4000 lbs plus, so the industrial model should be heavier than that. The work you are doing will depend on whether or not it is suitable. If it isn't, you should be able to sell it for what you have in it. Military owned equipment typically has low hours and excessive maintenance. Purchase with confidence in this matter. Some of the air compressors we used in the mid 90's were WW2 equipment. They always started and ran with no trouble. Generators and lift equipment were generally from the 50-60's. To give you an idea about the low hours, normally there was about 10 times the inventory of what was actually needed on a day to day basis. The Canadian military might be different from the USAF, but I wouldn't think so...
HTH
Aaron
