Calling Owners.....of Special 44D injector pump t
Ida Red
11-18-2006 19:55:46
Could anyone provide me with the correct timing on my Special 44D injector pump.On top of the PSB-injector pump while sitting on the seat, the lines on mine go out in this order (staring from the rt front corner)in a counter-clock direction 1,3,4,2.Is this the correct sequence. The engine has a miss and I am trying to figure out why. Thankyou Massey men. Red...Nov.18,2006
mn.Chuck
11-20-2006 15:03:01
 Re: Calling Owners.....of Special 44D injector pu in reply to Ida Red, 11-18-2006 19:55:46
IDA, Just as with checking a gas engine for a bad
spark plug, loosen each hi press inj line while
running and see which least affects the running of
the engine. Also pull the suspected injector out
and reconnect to the press line-then start and
observe spray. If spray pattern is "ragged" and
not a fine spray the injector probably needs to be
cleaned or serviced. This info in the service man.
Chuck
44 special
11-20-2006 13:26:10
yes this is the same order as mine, you may have a bad injector
Ida Red
11-20-2006 20:58:42
 Re: Calling Owners.....of Special 44D injector pu in reply to 44 special, 11-20-2006 13:26:10
Thanks a lot guys this really helps a green-horn like me.Red
