44 special
Floyd
08-22-2000 08:39:17
I have a 44 Special (gas) can anyone tell me what the "special" means, is there something different about this model compared to a 44 massey harris. I dont see anything really differnt about this tractor. No power steering, no three point hitch, no air(just kidding)can anyone tell me about his tractor.
Thanks
Tom E
08-29-2000 15:14:17
 Re: 44 special in reply to Floyd, 08-22-2000 08:39:17
The 44 Special replaced the 44 in 1953. Both models were made that year. The H260 engine of the 44 was replaced by the H277 in gasoline models only. The H260 was retained for kerosene and propane as was the HD260 for diesel.
The difference between the two engines is an increased cylinder bore. The H260 had a bore of 3.75" while the H277 had a 4" bore. This was done by inserting sleeves with the larger bore as the two engines share the same block, head and crankcase. Many H260 engines in 44's were rebuilt with the larger sleeves. This was called a "power up "kit.
The front wheels were changed from stamped steel to cast iron. The rear wheels on standards were changed to a different pattern which took a different style rim than the 44. Row crops retained the cast rear wheel introduced on late 44's.
Standard 44 Specials had a longer front frame than the 44 standard. This was the same frame used on the 44 row crop and 44 Special row crop. As a result the fuel tank was the same for the 44 Special standard as the row crops to make up the distance. 44 standards have a shorter fuel tank. (19 gallons as opposed to 23).
44 Special row crops featured a step for fueling the tractor and 44 Special standards came with wide fenders and a bigger operators platform as standard equipment. Later 44's came with narrow fenders as standard equipment.
44 Specials were made until 1955 when replaced by the 444.
don
08-29-2000 16:41:00
 Re: Re: 44 special in reply to Tom E, 08-29-2000 15:14:17
The H260 had 3.8125 ( 3 7/8)
the h277 was 4.00
Don
08-28-2000 14:51:33
The "special" has the 277cid engine over the h260.
the specials also had cast steel rims, instead of stamped steel. this made the tractor about 1000lb.s heavier. normal 44's where made from 1946 to 1955. specials where built from 53 to 55
Floyd
08-29-2000 08:16:39
 Re: Re: 44 special in reply to Don, 08-28-2000 14:51:33
Thanks for your comments Don.
Are the engines the same and just bored out a little more.
Floyd
Greg Powell
04-05-2002 06:05:34
 Re: Re: Re: 44 special in reply to Floyd, 08-29-2000 08:16:39
Need a new or good used Tie Rod Assy. (left side)
for Massey Harris 44 Special. Does any one know if these parts interchange from another tractor?
Thanks.
Jeff
08-24-2000 06:39:55
The 44 specials had the 277ci vs the 44 having the 260ci engine ( they both were continentals ). The row crops were the same length, but the standard model 44 was 7 inches shorter than a 44 special. Most 44 specials also had live pto & disc brakes, whereas a lot of the 44s did not have live pto & had drum brakes. 3pt was also a more popular item on the 44 special.
Alberta Mike
08-23-2000 06:15:14
Jim is probably right about the engine displacement increase, and somebody told me once that the front tub of the tractor is a bit longer, maybe a few inches. Don't know what that would do other than increase the wheelbase. Maybe some of the front sheet metal would also be longer as well. It's just what I was told. Otherwise, it was probably no more than a marketing gimmick, ie. changing the model designation, sort of a 'new improved' version like laundry detergent.
Jim Harp
08-22-2000 13:03:16
A somewhat greater displacement in the engine maybe 20 cu.in.. Not sure if the engine is Massey or Continental.
