Need photos of control lever arm bracket, MF34 Loa
Merlin W. Phill
11-16-2006 20:39:37
Hi there, I need to get my hands on a couple of photographs of the control lever bracket for a MF34 Loader. Just purchased one, but when it was delivered, the bracket is missing. I can fabricate one in my shop but really need to see what it should look like.
thank you in advance,
Merlin
Merlin W. Phillips, Jr.
11-17-2006 17:09:54
 Re: Need photos of control lever arm bracket, MF34 in reply to Merlin W. Phillips, Jr., 11-16-2006 20:39:37
No, actually the bracket that mounts on top of the valve block and holds the two valve control levers that you use to operate the bucket and lift.
V/R
Merlin
135 Fan
11-17-2006 21:53:38
 Re: Need photos of control lever arm bracket, MF34 in reply to Merlin W. Phillips, Jr., 11-17-2006 17:09:54
I have some very poor pictures but it looks like the hydraulic valves mount right onto the the back of the upright that serves as the oil tank. The valve is mounted vertically but I can't see exactly how it is mounted. Sorry I couldn't be more help. A dealer may have an old parts book with a good picture. Dave
11-17-2006 22:04:13
 Re: Need photos of control lever arm bracket, MF34 in reply to 135 Fan, 11-17-2006 21:53:38
I'm sorry that I did not make myself clear. I know how the valves mount. (they are mounted) What I need is a photo of the bracket that the arms that you move to actuate the valves. This bracket would have the pivot for the arms. (actually if I was taking the photo, I would focus on the top of the valve body.) I have a parts book ordered, however, what I want to do is to duplicate the bracket in my machine shop.
However, thank you for the reply.
V/R
Merlin
135 Fan
11-18-2006 01:05:58
 Re: Need photos of control lever arm bracket, MF34 in reply to Merlin W. Phillips, Jr., 11-17-2006 22:04:13
I think that each handle might have a seperate bracket because the lift [outer] moves further because of the self levelling. My pictures aren't clear but if I remember it is a Parker Hannifan control valve. A good hydraulic shop may have a picture of the handle pivots. Sorry I didn't have a better picture. You could try posting on the crawler forum as well. 34's were a common loader on MF30's and 40's. Dave
135 Fan
11-17-2006 11:46:32
Are you talking about the bucket level indicator? It is about an inch wide and comes to a point to line up on the top of the curved piece on the boom. It has a hole for the cable from the bucket linkage about 3/4 of the way down near the point. It is also mounted with a recoil spring to make it return. Hope this helps. Dave
