Wiring MH 30
Jerry
08-21-2000 21:19:26
The manual shows two wires from the generator, one from the brushes and one from the cutout relay. It also shows one wire from the coil. These three go into a harness that has two wires coming out at the other end, one going to the ignition switch and the other to the ammeter. Am I correct that the coil and the relay are connected and go to the ignition switch? That would mean that the remaining wire from the generator goes to the ammeter. If I'm wrong, how are they supposed to be connected? Any suggestions on running this as a negative ground system?
