OVERHEATING massey ferguson 35
Dr. LB
08-20-2000 21:09:29
have 1965 MF 35. Very older model. 4 cylinder gasoline engine PROBLEM: loses power and engine gets warm while bush hogging. Backfires consistently when powered off.
any suggestions or ideas desparately needed and appreciated
Gary V
08-25-2000 18:36:33
 Re: OVERHEATING massey ferguson 35 in reply to Dr. LB, 08-20-2000 21:09:29
Check the engine timming. If it is off, it will run hot and you will loose power.
CHRIS-MF35
08-23-2000 16:45:17
mine did the same thing one year ago when i bought it. the more i ran it the sicker i got. rebuilt the carb (soak well in carb cleaner) the man i bought it from had also turned the mixture screw way in to get rid of the puff of black smoke (this is normal) when the throttle is pulled back rappidly. i use mine about 8 hour a week in the summer, boy does it really drink the gas like everyone sayes, about 1.25 gal per hour mowing with 72 inch mower, my snapper used a lot more gas. the only problem i have with it is the power steering (it has none). good luck.
Fred OH
08-24-2000 14:18:30
 Re: Re: OVERHEATING massey ferguson 35 in reply to CHRIS-MF35, 08-23-2000 16:45:17
Those old Fords (9N) were designed to plow an acre an hour on a gallon of gas. With almost double the horsepower as a Ford, I don't think that 1 1/4 gallons an hour is excessive. Also, on the heat thing, a rich fueled engine will run cooler than a lean fueled engine if everything else is up to snuff. L8R----Fred
CHRIS-MF35
08-24-2000 17:43:47
 Re: Re: Re: OVERHEATING massey ferguson 35 in reply to Fred OH, 08-24-2000 14:18:30
FRED: i was joking to bad they took out the rolly eyes feature. the diesel owners arround here like to talk about how bad the gas tractoers burn fuel. i really don't think they have ever owned a gas one, or they would see that any old massey with live pto is a dream to own and easy on the fuel.
peter cullen
08-08-2002 04:17:21
 Re: Re: Re: Re: OVERHEATING massey ferguson 35 in reply to CHRIS-MF35, 08-24-2000 17:43:47
Can you help me with this,diesel 35 fergy has hissing sucking sound coming out of the donk-motor when she's idling and radiator has bubbles coming up. Is this what i suspect a wrecked head gasket and manifold etc.
stanley carter
08-21-2000 09:13:38
You might try and replace your thermostat.Same thing happened to me and I feared the worst but I replaced the thermostat and it took care of it my problem.
