MF235
LarryD.
11-11-2006 13:54:53
Well I checked out the Tractor Yesterday, and it"s a 235, insteasd of 245 W/11 Hundred hrs on the meter.All Straight Tin,always Garaged Cranks and Runs Great, Gears Tight,he want $6,500 for the tractor and Bhog and almost New Disc harrows, What else do i need to Check on Guys.
MF#1
11-11-2006 16:31:46
 Re: MF235 in reply to LarryD., 11-11-2006 13:54:53
Haven"t been around a 235 much, don"t think they made that many of them for very long. As I "remember" they weren"t a lot different than the 245. Maybe a lighter front axle? Is this one a diesel? How worn are the foot pedals-clutch and brake? Tires replaced or dry cracked? I would want that bush hog hooked up to check how the pto clutch works and how the lift works. Don"t know your area so can"t guess on a price, too much for a gasser though.
LarryD.
11-12-2006 17:46:06
 Re: MF235 in reply to MF#1, 11-11-2006 16:31:46
Ya; it's a DIESEL and Starts before You even hear the Starter, about half tire Tread and the Poewe Steering, with the Engine running I couldn't see any excess Movement as One Guy suggest I check..
naz
11-13-2006 04:56:04
 Re: MF235 in reply to LarryD., 11-12-2006 17:46:06
The seal where the PS arms go into the pump is where mine went bad.Maybe some fluid there if there is going to be trouble.
Naz
135 Fan
11-12-2006 18:27:02
If everything is good, $6500 is a very good price for a low hour diesel tractor with a couple of implements. Maybe a dealer could tell you more about what problems the steering had. Dave
135 Fan
11-11-2006 17:16:31
That's a good price. 235's were only made two years I believe. They are an updated 135 with the same sheet metal as the 245's that replaced them. I think the biggest problem with them was the power steering blowing out quite regularly. I'm not sure if you could get them with manual steering. It would be the best way to go. Big Dean or others on here would know more what to look out for. There must have been a reason they were only made for a short time after the huge selling 135 and then replaced by the 245. Engine and everything else should be the same. Check out the problem areas before buying would be my advice. Maybe they can be fixed or updated reasonably? Hope this helps. Dave
