35 diesel radiator not circulating
ric1
11-11-2006 10:02:53
i changed the antifreeze in my mf-35 with the perkins diesel i poured in first a gallon of antifreeze then topped it off with water. after letting it run for about 5 min the water seems to be still at the top of the radiator and i cant see any circulating motion going on inside the radiator is the pump weak or whats going on thanks RICK
JJ. in B.C.
11-11-2006 21:35:15
 Re: 35 diesel radiator not circulating in reply to ric1, 11-11-2006 10:02:53
Best to mix your antifreeze 50/50 with water before you put it in !!
JJ.
Dean
11-11-2006 16:47:21
Ric:
You will need to get the engine up to temperature so that the thermostat opens. This design bypasses lots of coolant around the radiator, and simply idleing the engine for five (or even 25) minutes will not raise the engine temperature enough to open the thermostat.
You can do this by working it or covering the radiator core with paper, etc. and running the engine until the lower radiator hose is warm.
Dean
ric1
11-12-2006 03:16:08
 Re: 35 diesel radiator not circulating in reply to Dean, 11-11-2006 16:47:21
thanks dean i was gonna try that next
