massey 245
LarryAD.
11-08-2006 14:00:01
I"m looking to buy a GOOD garden Tractor, for occasional Bushhogging and Small Garden Work, on about 18A. A gentleman has an 80"s?? Yr model "245" w/Bhg,and harrows always sheltered Sheet matal Straight... haven"t seen it, but will Fri, QUESTION<> What are the Pro"s and cons on these,I haven"t Bought so lets have the Opinions, Thanks Guys..Larry
chad 9999
11-09-2006 21:00:31
 Re: massey 245 in reply to LarryAD., 11-08-2006 14:00:01
i have a 245 and i would not take a million $ for it ..... well 7000 would buy it today they are great tractors the only issue with mine is (and all diesel are different) but under 40 in temp and have to plug it up
GaryF
11-08-2006 19:59:48
The only negative that I could add is that many 245's smoked a fair bit on startup particularily in colder climates. Many of them had their pistons changed for the earlier 135 type by the selling dealers to avoid complaints.
Gary
smokey2
11-08-2006 17:21:57
Check out Big Deans site for buying hints.
MF#1
11-08-2006 15:59:58
Great tractor, diesel has more power than it needs. Actually the power steering has the 'potential' to be a problem. One I have has over 4100 hours and had to get the power steering cylinder rebuilt about two years ago, parts were pricey, $600+ for the cylinder, no one rebuilds them aftermarket. If this is a fairly low hour tractor it shouldn't be a problem. Watch the tie-rod end movement, running, while moving the steering wheel slightly. The tie rods are part of the cylinder shaft and are not replacable individually. Our other 245 has about 1600 hours with no steering probs. Neither has multi-power, one 6 speed, one 8 speed, I actually like the 6 speed better. Do a search for 245 on this page and read up, go to fastline dot com to get a general idea of selling prices in your area. Dry brakes don't have great stopping power but are ok for light work. I don't think you can beat one for its size.
TXFIRE
11-09-2006 11:42:28
 Re: massey 245 in reply to MF#1, 11-08-2006 15:59:58
I carry the rebuild kits for the 245 cylinder and cylinder rods new. I am working on getting the cylinder at this time. This site buys parts from us sometimes but I don't know if they buy these parts yet.
TXFIRE
LarryAD.
11-09-2006 06:06:30
this One hs about 1 thousand hrs on it, Will Look at it Tomorrow. I app. Your response I'm sure I will have further Questions.
135 Fan
11-08-2006 14:35:24
Excellent tractor! An updated 135 with better power steering. A lot more than a garden tractor. Check it out first though. They were made from about 76 or 77 and well into the 80's. If it's a diesel, it's even better. Dave
