56 MH 50
Kevin
11-08-2006 13:46:15
I have a 56 MH 50 rc, the motor is burning a decent amount of oil. I was wondering if i go to a junkyard what motors will fit in this tractor. If i can find something bigger that would fit without alot of trouble it would probly be worth while instead of a rebuild. Is there and diesel engines that would swap without troble to or is it easier to stick with a bigger gas engine if any? This may be a future puller project.
phil(va)
11-09-2006 10:18:23
 Re: 56 MH 50 in reply to Kevin, 11-08-2006 13:46:15
What Illinois Steve says. Also, if you have the Continental Z134 engine, which I think you do, that is the same engine as in the Ferguson 40, MF 50, and the Ferguson TO-35. Quite a few of the latter tractors were made. You might get an engine from one of the bone yards. Try MAC Tractor in Colcord, OK. They have a good selection of used Ferguson parts.
Illinois Steve
11-09-2006 07:38:36
Kevin First of all I'm no expert on this, but I've been told that the Massey Ferguson 50 is the same tractor just different names. The Massey Ferguson 50 did have a diesel motor available. Don't know if it will work, but it would seem like a lot of extra work to change. It would probably be easiest and cheaper just to rebuild your present motor and keep it original. Just my thoughts
Steve
