MF 50 valve adjustment
Dan from PA
11-08-2006 10:24:29
I have a MF 50 with a continental z134 motor in it. I was wondering if anyone knows what the cold valve adustment is for this motor? Also does anyone know what the head bolts are supposed to be torqued to? Thanks.
Badly Bent
11-09-2006 04:19:05
 Re: MF 50 valve adjustment in reply to Dan from PA, 11-08-2006 10:24:29
Dan, I don't have a Z134 but I do have a Z145 in my 135. As I understand it the heads on these engines are interchangeable (in fact the head on my tractor says Z134) so this information should work. The information is from the Massey Ferguson Service Manual.
Cold settings: Intake .013 Exhaust .015
Head bolt torque: 70-75 ft-lbs.
Tim
Dan in PA
11-09-2006 07:31:31
 Re: MF 50 valve adjustment in reply to Badly Bent, 11-09-2006 04:19:05
Thanks alot for your help. Hopefully I'll get the tractor put back together this weekend. About two weeks ago I developed a dead miss. I pulled the valve cover off and saw that the intake valve retainer had broke on the #1cylinder. They only thing that keep the valve from completely dropping was the pin that goes through the top of the valve. Again thanks.
Rusty Junk TX
11-09-2006 03:22:09
My I&T Manual for my MF50 says .013 HOT OR .015 COLD for both int and exh. Head torque 70-75ft.-Lbs.
Marcus
Aaron Ford
11-08-2006 18:46:42
Okay, don't have the manual for the Z134 but I have one for the G176 (MF65). So here goes
Head bolts 75 foot/lbs
Intake, .016
Exhaust, .018
Think yours is similar?
