97 REAR END NOISE
DuaneMN
11-04-2006 15:05:14
Just bought a 97 on an auction and it has a BAD noise in 5th gear especially when slowing down -- any ideas??? Also misses when cold -- gets better when warmed up -- any more ideas???? Tin is perfect!!!!!
brianriver
11-04-2006 15:34:09
 Re: 97 REAR END NOISE in reply to DuaneMN, 11-04-2006 15:05:14
You may have to put a load on it in all gears to see if it is 5th gear specific. If you have noise in all gears, you may have differential, tranny or bull gear problems such as worn bearings or gears. I think 5th gear is direct drive, so no counter shaft action or load on it. If it is only 5th gear, my best guess is that the main shaft has worn bearings and is making noise. When slowing down, the load reverses on the gears and if the bearings are sloppy, the gears in rear end, ring and pinion or tranny, where ever the bad bearings are at and those respective gears ride up on each other in a different place and make the noises you are hearing. As far as running, maybe the tractor has set for a while and has old fuel. Drain it, start with a few gallons of new and see if it goes away. Try the cheapest tricks first,
