135 massey trans
gardner haddix
11-04-2006 18:24:33
i found a great looking 135 but the 6 spd trans has been blown outwith no way to repair it. i would like to by it but no one can tell me what all wold fit it. i would like any info anyone can give me thanks.
DavidP, South Wales
11-05-2006 05:06:36
 Re: 135 massey trans in reply to gardner haddix, 11-04-2006 18:24:33
Hi,
What is wrong with the transmission? Is the casing broken or just internal? The six speed is a relatively simple unit that can be stripped and rebuilt with a minimum of tools. A good workshop manual is essential though. With this unit you have a choice on gen or non-gen parts and there should be secondhand ones around.
DavidP South Wales
gardner haddix
11-05-2006 05:58:32
 Re: 135 massey trans in reply to DavidP, South Wales, 11-05-2006 05:06:36
the bottom and side has 2 big holes in the casing. someone tried to patch it with fiberglass.the holes are big enouph to put both of your fist threw. it will move on the low side with alot of noise. foget the high side of it. i have rebuilt 8spd ford trans so that is no problem. thanks for any info you can me davidp
Bert CA
11-05-2006 06:18:49
 Re: 135 massey trans in reply to gardner haddix, 11-05-2006 05:58:32
Hi
It seems that MF-135 - MF-150 - MF-165 MF-35 - MF-50 - MF-65
Had same transmission and casting
Should be afortable from a tractor boneyard.
Bart
gardner haddix
11-05-2006 08:54:27
 Re: 135 massey trans in reply to Bert CA, 11-05-2006 06:18:49
thanks davidp and bert ca for the info.
DavidP, South Wales
11-05-2006 08:20:36
Hi, I agree with Bert. A breakers would be a good start. Try and find a tractor that has been written off. The chances are that the transmission will be in good condition. If you have experience of transmissions then that improves your chances of finding one and getting the tractor going at lower cost.
DavidP
