tach drive lube on 135
in sticks
11-03-2006 17:26:05
on a 135 gas with the 4 cyl engine the tach is driven from the rear of the gen.what lube do you suggest for the little gearbox on the rear of the gen?
BigMarv1085
11-04-2006 06:36:52
 Re: tach drive lube on 135 in reply to in sticks, 11-03-2006 17:26:05
I use a shaft grease made by dow corning. Its pink and has the consistencity like lubriplate. White grease works well.
Gerald J.
11-03-2006 18:12:46
My owner's manual ('68 vintage) says nothing about lubricating the gear box. Doesn't even show it though it shows the Continental engine that uses it. It does say that the oilers front and rear on the generator should be filled with light engine oil every 100 hours.
Gerald J.
