102 Sr. transmission
Phil Johnson
11-02-2006 17:54:43
I have a '42 Massey 102 Sr, distillate 244 engine. What is the correct gear oil for the trans? It currently has 600 wt gear oil and the shift lever can't be moved at sub-zero temps. Can I go to a lighter oil? I'm an Allis guy and am not familiar with this unit.
Phil Johnson
11-04-2006 06:58:02
 Re: 102 Sr. transmission in reply to Phil Johnson, 11-02-2006 17:54:43
I pulled the drain plug and let it drain all night in the shop. Lots of rusty, heavy oil and ice chunks. Flushed it all out and replaced with 85-140 gear lube. Seems to be OK now. Thanks for reply
Alberta Mike
11-03-2006 05:16:16
Hey Phil, changing colors are you? I think the manual recommends 140 gear lube for all those Seniors and Juniors (same tranny and differential) but I have used 80w90 in my Junior and it seems to work fine without too much noise, etc. This weather sort of snuck up on us, I might drop by today, you were out on Tuesday when I showed up.
