255 Oil Pressure Gauge Question
pbutler
11-02-2006 15:21:03
My 255 sprung an oil leak under the dash today. Upon closer investigation there is a brass Tee coming off the oil pressure gauge. One end had the flexible oil line going to it-which is not leaking.
The other part of the Tee has a 50 cent piece sized round thing with two terminals on it. That is what is leaking.
When I disconnect the terminals the pressure gauge still works properly-but the fuel gauge drops to empty.
What the heck is that piece and what does it do besides provide power to my fuel gauge?
Big Dean
11-02-2006 17:49:13
 Re: 255 Oil Pressure Gauge Question in reply to pbutler, 11-02-2006 15:21:03
That oil pressure switch is for exciting the regulator in the alternator to make it charge and turning on the fuel gauge. Things done with the ignition switch on a gas engine.
pbutler
11-03-2006 07:07:41
 Re: 255 Oil Pressure Gauge Question in reply to Big Dean, 11-02-2006 17:49:13
Man, you guys are awesome! I have spent 30 minutes on the phone with parts lady who can't find it and didn't know what that would be for.
Also explains why my alternater hasn't been charging for a while.
135 Fan
11-02-2006 15:47:31
It might supply power to all the electrical accesories and only works when you have oil pressure. Dave
Bob
11-02-2006 16:57:42
 Re: 255 Oil Pressure Gauge Question in reply to 135 Fan, 11-02-2006 15:47:31
Or, if it has an electric hour meter, it will be the switch that activates the hour meter, as long as the presence of oil pressure indicates the engine is running.
Common name, after the manufacturer is "HOBBS pressure switch".
