MF 275--BRUSH HOG RPM'S
SCHAP
11-02-2006 11:55:39
HOW HIGH SHOULD I WIND UP MY MF 275 4CYL PREKINS DEISEL BEFORE CUTTING WITH THE BRUSH HOG? MY TACH WORKS, BUT IS NOT MARKED VERY WELL. ALSO, WHY DO THEY CALL IT A 540 PTO, WHEN I'M SURE IT'S GOTTA BE REVVED UP MORE THAN THAT? JUST WHAT DOES THE 540 MEAN? THANKS FOR ALL THE HELP ON ALL MY QUESTIONS.
Boss Hog
11-03-2006 05:44:22
 Re: MF 275--BRUSH HOG RPM'S in reply to SCHAP, 11-02-2006 11:55:39
Typing niiall capital letters is like shouting, and is considered to be rude.
pbutler
11-02-2006 15:17:37
I have a 255-I think my 540 line is right about 2000 RPMs-will look next time I go to the shed.
135 Fan
11-02-2006 15:49:11
 Re: MF 275--BRUSH HOG RPM'S in reply to pbutler, 11-02-2006 15:17:37
2000 is probably for belt speed not PTO speed. Dave
pbutler
11-03-2006 10:01:47
 Re: MF 275--BRUSH HOG RPM'S in reply to 135 Fan, 11-02-2006 15:49:11
Weird. I just looked and I have 2 lines-both with little arrows pointing to a PTO shaft picture in the middle of the tach. One line is at 1720 and the other is at 2000.
I bet your are right-1720 is the 540. If that is true then 2000 would put it at about 630. Is that the low and high end and 540 is in the middle or something?
BigMarv1085
11-04-2006 06:43:14
 Re: MF 275--BRUSH HOG RPM'S in reply to pbutler, 11-03-2006 10:01:47
I would say 1750, thats what my 135,175,180,And 1085 require forr 540 rpm.
135 Fan
11-04-2006 09:44:34
 Re: MF 275--BRUSH HOG RPM'S in reply to BigMarv1085, 11-04-2006 06:43:14
I've seen it as low as 1680 rpm's. Anything around 1700 or 1750 wouldn't make much difference in the pto speed. Dave
135 Fan
11-03-2006 10:49:46
There is no high and low end. Some implements can be run faster or use power under load and then the the tractor has to be revved up to keep the proper 540 pto speed. When you put a belt pulley adaptor on the pto shaft 2000 engine rpm gives the proper pulley rpm for the belt. I have a UK tractor with a tractormeter that says pto speed and belt speed. I looked in the manual and found the belt speed is approx. 3100 ft per minute at 2000 rpm. Hope this answers your question. Dave
135 Fan
11-02-2006 12:33:01
540 is the standard PTO rpm for smaller tractors. Bigger tractors have 1000 rpm PTO's and some tractors have both. They have different splined shafts. The gear box on your mower speeds up the rpm to the proper speed for your mower. I'm guessing you need to have the tractor at around 1700 rpm for a 540 pto rpm. That's what it is on smaller MF's. About 3/4 throttle. There might be a line on your tach to line up the needle of the tach. Engage the pto at idle and then speed up engine. Hope this answers your questions. Dave
SCHAP
11-02-2006 12:54:18
 Re: MF 275--BRUSH HOG RPM'S in reply to 135 Fan, 11-02-2006 12:33:01
NOPE..NO LINE ON THE TACH.THAT'S WHY I WAS UNSURE OF THE RPM'S. YOUR ANSWER WAS HELPFUL...THANKS.
Roy in UK
11-03-2006 22:13:37
 Re: MF 275--BRUSH HOG RPM'S in reply to SCHAP, 11-02-2006 12:54:18
Your tractor tach. does not work you say, does your caps lock on your computer?
Don-Wi
11-03-2006 23:30:03
 Re: MF 275--BRUSH HOG RPM'S in reply to Roy in UK, 11-03-2006 22:13:37
Yup, it works real good...
