Massey Harris 50 horsepower
Frank G
08-17-2000 05:33:43
I just aquired a Massey Harris 50. I do not know much about these because it is only my 2nd tractor. Had 9N before. The MH was to good a deal to pass up. Good sheet metal, no rust,no dents, good running & clean tractor with a 6' kingcutter finish mower for $1000. I am curious as to what Hp this tractor has. I was told 33hp at pto. Also, the clutch seems to be out of adjustment. It will shift gears fine, but you have to depress halfway for that & then depress more to engage PTO. However, the PTO will not engage by doing this. Have to have tractor engine shut off to engage/disengage PTO. Other than that it operates great. Does this sound serious or is it just a matter of adjustment?? I was told that the 9N was just as strong as the MH, but so far I have to disagree.
B.C.
08-17-2000 05:46:37
 Re: Massey Harris 50 horsepower in reply to Frank G, 08-17-2000 05:33:43
1. There have been a bunch of posts on the hp. 32 33 hp is about right for PTO hp for a gas engine.
2. Sounds like the clutch needs adjusting. Also be aware that there are two PTO modes, ground drive and engine PTO. Engine PTO is up, neutral is middle, ground drive is bottom. Should say that next to the lever.
3. I grew up around a 9N and was very pleasantly surprised how much nicer the MH50 was when we got ours some years back. Lots more guts, live pto, yet nearly as maneuverable and flexible as a 9N.
They do have a few quirks but they sure can be coped with. If you get sick of yours let me know and I'll show up with a $1000.
Frank G
08-17-2000 05:51:33
 Re: Re: Massey Harris 50 horsepower in reply to B.C., 08-17-2000 05:46:37
Thanks for your help, but I don't think I am going to get sick of it any time soon!!!
