MF50 will not stay running
mevans
11-01-2006 08:24:45
I have a Massey Ferg. MF50 that will crank, and run for about 2 or 3 minutes, and will shutoff. New carberator has been installed (thought it was the carb), old carb was doing the samething. Getting plenty of gas. Any ideas?
kendall mortenson
11-21-2006 17:34:43
 Re: MF50 will not stay running in reply to mevans, 11-01-2006 08:24:45
just a thought,,but did you check the air cleaer too?its such a simple little thing that it could be overlooked easily.
supergrumpy
11-01-2006 11:08:48
quick test:
pull off the rubber hose between carb and air cleaner, start engine, as it dies spray teeny bit of starting fluid into carb
if it catches and runs a bit, you have gas starvation, if no change then you have ignition problem to hunt down
to check gas flow, pull carb drain plug, run gas into big coffee can, if you can fill the can without flow slowing down any, your entire gas supply line is OK
Joe Ferguson
11-01-2006 09:13:17
Hi
First thing you may check if you have the right gas cap on the tank it is supposed to have a vent to permit air to go in the tank when gas getting out.
For a test you can run it with gas cap loose and see if it is OK.
If it"s not the cap you may disconnect the gas line fitting at the carburator catch the gas with a can open the valve at the tank you supposed to have steady full tube gas flow.
Just my 2�
Joe Ferguson
mevans
11-01-2006 12:42:09
 Re: MF50 will not stay running in reply to Joe Ferguson, 11-01-2006 09:13:17
I can disconnect the gas line from the carb, and gas will steady flow. Should I still try the drain plug from the carb? You guys have been a great help so far, still troubleshooting.
supergrumpy
11-01-2006 13:44:59
 Re: MF50 will not stay running in reply to mevans, 11-01-2006 12:42:09
once in a while a carb float is bent enuf to hang up or crud reduces flow inside the carb, it reduces the flow and fuel level will drop while engine is running, when tractor drains the bowl the engine dies, doing the bowl drain will check that too
BUT, you said both carbs did same thing so you likely have something else wrong, try the ether in case its an ignition problem
