perkins bubbles from radiator-cracked head?
mmidlam
10-31-2006 08:24:18
have a MF 150 with 3cylinder perkins diesel. It bubbles from radiator. I tried to locate which cylinder is leaking by loosening one injector line at a time. It appears all cylinders are shooting air into the water jacket. How could this be? Do water glass products ever work for a deisel?
BigMarv1085
10-31-2006 17:58:12
 Re: perkins bubbles from radiator-cracked head? in reply to mmidlam, 10-31-2006 08:24:18
You have a choice of 3 things, Cracked head, cracked sleeve, or blown head gasket. I have worked on several engines that had cracked sleeves and usually the tractor doesn't run hot,it will have coolant streaming out the overflow tube and usually stops at idle.
TomTX
10-31-2006 17:00:03
I would NOT put any "snake oil cures" like liquid glass in an attempt to fix this problem. Pull the head and fix it right. Tom
peltsi
10-31-2006 09:40:23
i'm not sure if removing an injector line would stop the leak from the faulting cylinder, since there would still be the compression leaking throught. I think the best idea would be to remove the head and see what's causing the trouble. From my experience, those radiator sealants just cause trouble by gumming places up.
DavidP, South Wales
10-31-2006 09:37:18
A cracked head is certainly a strong possibility.
Equally likely is a failed head gasket. Slackening the injectors would not necessarily indicate this. I don't think that there is much short of removing the head. Make sure that the head face is skimmed before replacement. Come back if you need any more help.
DavidP
