MF135 Perkins diesel
Deane
10-31-2006 05:33:37
My neighbor has a leak on the injector pump on his Perkins MF135. There is a 1 inch by 2 inch cylinder on the side of the injector that has a tube that goes back to the side of the transmission to a 1 1/2 inch round thing and a tube from there that goes up under the dash. Can he take the cylinder off the pump with no problems and what does it do. I can't find it in the maintenance manual. Thanks
smokey2
10-31-2006 13:43:56
 Re: MF135 Perkins diesel in reply to Deane, 10-31-2006 05:33:37
The pipe sounds like the return line. It will have a rubber olive fitted to the end which may require replacing if that is where it is leaking.
