mf-165 freeman loader
ric1
10-30-2006 09:38:19
i just purchased a 165 with a freeman loader . the loader hasnt been used for a while so i was going to replace the hyd. oil in the loader its driven by a front pump on the crank with the oil in the loader frame work . do i use trnas/hyd. oil or regular hyd. oil in this and does anyone know the oil capasity for this loader its a freeman 4000 thanks RICK
135 Fan
10-30-2006 09:51:42
 Re: mf-165 freeman loader in reply to ric1, 10-30-2006 09:38:19
I use the same oil I have in the trans for most of my hydraulic needs. For seperate hydraulic systems I use an equivelent to MF oil because the dealer is too far away. In the trans though only MF oil. The other oil says right on it that it's good for seperate hydraulic systems. You could use it or reg. hydraulic oil. For capacity put a few gallons in and cycle the system a few times. Add oil to where it is below the filler 3 to 6 inches with all the cylinders retracted. This allows for expansion when it gets hot. If it's over filled it will leak out the filler vent. Dave
