Big Dean Multi-power Question
rrbgtt
10-30-2006 04:52:44
I received your drawing on bolting the multi-power clutch together on the 165. Thanks. I also have a 1150 with a bad multi-power. Do you think that this will also work on this much HP, since it really is mainly engaging a gear not transferring power?
brianriver
11-01-2006 07:53:13
 Re: Big Dean Multi-power Question in reply to rrbgtt, 10-30-2006 04:52:44
1150 multipower is not too bad of a job for the mechanically inclined. The clutch pack sits behind the front cover of the tranny and if pump pressure is ok, clutch discs, plates, seals, gaskets and hub have them up to speed in a day or less. Not the terrible job of the IH TA's where you have to pull tranny, stand it up on end and gently align wobbly disc plates as you set it down.
504-1
10-30-2006 19:29:05
I wont even predend to know as much as Big D but the 1150 has a completely differant hyd(MP)system than a 165.
