New Toy Revisited
Gary_N_WV
10-29-2006 17:02:36
third party image
I looked on the oil pan for the casting number and found 12 11 65.
Is this Dec 11 or Nov 12?
Which format is used ?
Also, if I can get it to work, here is a picture of the farmerized fuel filter.
Aaron Ford
10-29-2006 20:05:15
 Re: New Toy Revisited in reply to Gary_N_WV, 10-29-2006 17:02:36
I believe it is 12 day 11th month 1965. I will check and repost if incorrect.
135 Fan
10-29-2006 20:32:41
 Re: New Toy Revisited in reply to Aaron Ford, 10-29-2006 20:05:15
I think you are correct. Day Month Year. It does look like like someone took the glass bowl off. Dave
135 Fan
10-29-2006 20:46:01
 Re: New Toy Revisited in reply to 135 Fan, 10-29-2006 20:32:41
Sorry, I think it is Day Month Year because my UK model is 9 12 64 and they weren't introduced in the UK till 65. That would make yours an early 66 model I believe. Dave
Aaron Ford
10-29-2006 20:05:07
smokey2
10-29-2006 17:35:53
Looks like it is well due for a couple of new filters. May be worth replacing the odd filter with a generic CAV filter assembly. This site probably has them if not try Bareco and several other suppliers carry them.
Might be worth removing the fuel tank and giving everything a good clean. I located a damaged and leaking fuel line when I did mine along with a layer of packed straw between the tank and the engine.
