44 massey oil
Floyd
08-16-2000 08:15:55
The Massey i just bought appears to use the engine oil to run the hydraulics on this tractor, is this a common way of getting oil for hydraulics. What weight of oil should i be using in this tractor to supply engine and hydraulic needs. THANKS FLOYD
Alberta Mike
08-16-2000 18:32:32
 Re: 44 massey oil in reply to Floyd, 08-16-2000 08:15:55
You are maybe thinking that the engine oil is running the hydraulics due to the fact that if you have a Massey Harris factory hydraulic pump, it is mounted behind the location where you pour in engine oil, but it does have it's own supply of hydraulic fluid which is separate from the engine oil. Meanwhile, many newer tractors have common oil between the transmission, differential, and the hydraulic system, but not the Massey 44's. The supply tank for the 44's hydraulic oil was in front of the radiator (behind the grille) and you should have some sort of a top access to the tank so you can top up the hydraulic fluid. There should be a dipstick on this hydraulic fluid tank as well.
