mhf pinion
tractormatt
10-28-2006 21:16:05
working on a mhf40,found the pinion shaft loose,pulled pinion found pilot bearing broke, replaced all bearings(from a dealer),reinstalled pinion into case,installed pto drive gear,lock washer and nut.there is about 1/8 in. between the gear and the bearing like there needs to be some shims in there somewere but the book dont show them. any input would be apprieciated.thanks
Harris Guy
10-30-2006 17:21:59
 Re: mhf pinion in reply to tractormatt, 10-28-2006 21:16:05
Pinions take considerable stress, when tearing down you may not have found the shims, since they either never existed, or were chewed up with the years of shaft play. Having replaced MH pinion shafts, the banks, carriers, are tedious to keep you switching shim thickness, number, to get a
proper, snug fit throughout. The wear factor on old iron, makes you test your patience, take a
break, do some other work, to relax. Good luck placing shims, it's an exercise.
