MF265 - draft position control broken
MFdestroyer
10-26-2006 15:07:16
I've just broken off the draft and position control...don't ask me how it's too painful. Anyway the control unit has broke the casting and bent the rod to 40 degrees. I pulled it out and it has a spline on the end. The rod is tough..do I find a new rod or bent it back? Anyone else done this..any info appreciated.
richard in nz
10-26-2006 23:16:10
 Re: MF265 - draft position control broken in reply to MFdestroyer, 10-26-2006 15:07:16
You will have to lift off the hydraulic top cover and have the casting mended or replaced. If the rod can be straghtend so it will move without binding you may be able to use it again but the hydraulic system will have to be set up again using special service tools on the bench.
