replacing fan belt on a massey furguson
frank bentley 5
10-25-2006 09:03:48
old belt on a mf 2135 196- gone. I cant get enough space to replace a new one. How do you replace without taking the whole front end off?
Big Dean
10-25-2006 18:48:12
 Re: replacing fan belt on a massey furguson in reply to frank bentley 55, 10-25-2006 09:03:48
Do you have a front crankshaft driven pump that you are trying to get the belt past.
DavidP, South Wales
10-26-2006 00:37:18
 Re: replacing fan belt on a massey furguson in reply to Big Dean, 10-25-2006 18:48:12
HI, the first thing as Big Dean has said is do you have a crank driven pump? If not and as '135 Fan' has said there is a place to fit the belt. Looking from the tractor seat you will find a 'hump' in the radiator cowl at about the 2 o'clock position. Line up each blade and ease the old belt through and then the new one on. It is a bit of a wangle but it can be done quite easily. Ensure that the belt is in the water pump pulley before you adjust. It is easy to think its in.
DavidP
135 Fan
10-25-2006 12:37:07
It's been a long time but I think I had to find the biggest gap between the fan and shrould and turn the fan so a blade was there. Then I kind of carefully forced the belt in. If it's too tight maybe you can just take the fan off? Hope this helps. Dave
