On my MF-135 with two remotes added there are three hydraulic levers in front of the seat. The left one is a selector. In the mid position, the right two levers work the auxiliary hydraulic ports which would be your fork lift. The left lever has three latching positions. Forward it lifts the three point if the two levers to the right of the seat are full up, in the mid position it locks the 3 point and enables the auxiliaries, back, it lowers the three point. For auxiliary hydraulics to work, the front part of the PTO shaft has to be turning, so the double clutch bottom part has to be engaged, transmission gears don't matter, and the lift lever on the quadrant has to be in the constant pumping position and the draft lever all the way up. The ground/neutral/engine shifter on the left under the seat doesn't matter to the hydraulics either. But if in the engine position, the pump isn't running unless the external PTO shaft is turning. There are three ways to run the three point, and any of them can turn off the auxiliary hydraulics. Auxiliary hydraulics isn't covered in the owner's manual and I don't find that the triple valve is covered in the manual on auxiliary hydraulics. That manual is MF number 690 562 M3. Titled: "Operator's Manual. Basic & Auxiliary Hydraulic systems for MF 130 through MF 180 Tractors" Gerald J.
