Meters on the dash board ( MF 165)
Jicarre
10-24-2006 00:20:22
Hello everybody,
Several of screens on the dash board do not work.
The fuel tank meter, the ampmeter, and all the others...Do not move. Do you have an idea ? Are they broke wires ? Are they blocked because too old ? Or a connection or a fuse is burned ? Do you have an idea , do you have a procedure to check them ?
Many thanks to answer to me
Lee in MI
10-24-2006 07:26:55
 Re: Meters on the dash board ( MF 165) in reply to Jicarre, 10-24-2006 00:20:22
The voltage for the gauges is coming from a oil pressure switch if its a diesel. The key has only a start position so the oil pressure switch serves that purpose. Check the wiring for voltage after the switch and before the gauges.
Jicarre
10-24-2006 12:10:43
 Re: Meters on the dash board ( MF 165) in reply to Lee in MI, 10-24-2006 07:26:55
Thanks Lee,
It is a diesel (mod 66).
I do not know about the switch you speak about. I do not see witch one it is. There are few switches that I do not know what is their use. A lot of items are damaged on the dash board and the written advises are erased by the rust or the time... I am still waiting for the manual user,I ordered it,a few days ago. What is the oil pressure switch look like ? I noticed a RED SWITCH just near the head lights's switch (the one you turn to the right to get light). Is it that RED SWITCH?
Thanks for replying to me
Jicarre
Bob N.Y.
10-24-2006 17:35:21
 Re: Meters on the dash board ( MF 165) in reply to Jicarre, 10-24-2006 12:10:43
The switch he mentioned is behind the dash. Follow the small tube from the engine to the oil pressure gauge. You should find a fixture with a wire attached.
jicarre
10-25-2006 00:40:22
 Re: Meters on the dash board ( MF 165) in reply to Bob N.Y., 10-24-2006 17:35:21
OK BOB,
Thanks, I am going to check !
I will tell you soon !
