165 sending unit question
Gaplowboy
10-22-2006 19:46:31
hi: Does anyone know if a sending unit for a 240-250 MF would fit and work on my late model 165?
Thanks in advance; Gaplowboy
DavidP, South Wales
10-23-2006 02:33:14
 Re: 165 sending unit question in reply to Gaplowboy, 10-22-2006 19:46:31
Are you referring to the sender unit in the fuel tank? If so, in all probability the unit will fit and work to a point. The float arm for the 165 will be considerably longer. So whilst the other might work it will not be accurate in the lower regions.
135 Fan
10-22-2006 20:00:35
Sending unit for what? If they're mechanical gauges rather than electric, they come complete with gauge and sending unit. If it's the same size hole in the dash and same thread in the block, they should work. 165 gauges should be easy to get. Dave
135 Fan
10-22-2006 20:07:46
 Re: 165 sending unit question in reply to 135 Fan, 10-22-2006 20:00:35
Should clarify. Mechanical temp. gauge is one piece. Mechanical oil pressure is two piece, but the gauge and sending unit need to be calibrated to work with each other. Hope this helps. Dave
