freeman loader on a 165 mf
ric1
10-22-2006 17:59:20
doesnt the 165 have a hydralic capability to run aloader itself without using the front pump off the crankshaft
lonestarjeff
10-25-2006 18:30:53
 Re: freeman loader on a 165 mf in reply to ric1, 10-22-2006 17:59:20
Ric...I ran mine off the tractor's belly pump for a year before converted to a front pump. It used the quadrant lever to lift & lower the forks. The bucket was a trip-type. Other than being a little slow, the rear lift has to be locked down when you tap into the belly pump ports.
There are MF valves around that bolt onto the lift cover(in front of the seat)& divert oil to one or two circuits, but they were too pricey for me. Plus, this set-up also shuts off the rear lift.
Some 165's were equipped from the factory w/ internal auxillary pumps & control valve beside the seat. I've never heard how reliable they were, Big Dean would likely know.
Jeff
504-1
10-22-2006 19:44:36
Yes it will run the loader,it will be a little slow. We had one on a 65 and it beat the daylights out of a pitch fork.
MF Poor
10-23-2006 01:02:43
 Re: freeman loader on a 165 mf in reply to 504-1, 10-22-2006 19:44:36
Even beat TWO pichforks!
