LOADER: MASSEY FERGUSON MODEL M-F /38
SUT
10-21-2006 15:00:55
LOADER WORKED OK THEN DIDN"T,LOADER WORKED THEN DIDN"T, LOADER NOW WON"T WORK. ANY IDEAS???
ANY HELP WILL BE APPRECIATED. THANK YOU.
SUT
12-09-2006 11:13:42
 Re: LOADER: MASSEY FERGUSON MODEL M-F /38 in reply to SUT, 10-21-2006 15:00:55
FINAL RESULTS I THINK. REPLACED DAMAGED STANDPIPE. HAD ONE END DAMAGED, NOW WORKS OK. THANKS DAVE AND I DID CONTACT BIG DEAN. HE SETTLED ME DOWN AND TOLD ME TO TAKE MY TIME. TOOK SIDE PLATE OFF AS HE ADVISED AND LOOKED AROUND. THANKS AGAIN BIG DEAN. HOPE YOU ARE FEELING BETTER.
SUT
10-23-2006 08:41:38
135 FAN THANKS FOR REPLY. PURCHASED MASSEY FERGUSON 50 TRACTOR WITH THE LOADER A COUPLE WEEKS AGO. I DON'T KNOW MUCH ABOUT EITHER. SEEMS LIKE FLUID IS FULL. I HAVE A DIVERTER WHICH I REMOVED AND FOUND THE SHAFT DAMAGED A LITTLE ON THE BOTTOM . I DON'T KNOW HOW HYDRAULICS WORK. BUT IF THEY DID I MUST BE DOING SOMETHING WRONG????
135 Fan
10-23-2006 10:00:09
 Re: LOADER: MASSEY FERGUSON MODEL M-F /38 in reply to SUT, 10-23-2006 08:41:38
Also make sure draft control is all the way back and lift control is all the way back and pushed past stop and pushed back even further into constant pumping. Don't lift 3 PT. arms all the way up and if the diverter valve is in the right position it should work. If not, disconnect a hose and see if any fluid is pumping. Good luck. Dave
SUT
10-29-2006 07:59:04
 Re: LOADER: MASSEY FERGUSON MODEL M-F /38 in reply to 135 Fan, 10-23-2006 10:00:09
DAVE, THANKS FOR YOUR HELP. JUST STARTED TRACTOR ,HAD A GAS LEAK ,RPLACED BULB ON GAS FILTER-PURCASED FROM WEB SPONSOR-VERY QUICK SERVICE. NO FLUID IS FLOWING ?? FLUID IS WHITEISH ?? DIVERTER VALVE MOVES BACK AND FORTH EASIER THAN BEFORE ?? PLAN TO TAKE DIVERTER VALVE OFF AGAIN TO SEE WHAT'S UP. ANY OTHER SUGGESTIONS??
135 Fan
10-29-2006 10:02:08
 Re: LOADER: MASSEY FERGUSON MODEL M-F /38 in reply to SUT, 10-29-2006 07:59:04
If your fluid is white, you have water in it. If you have the clutch out it should work on one of the positions of the diverter valve. If not check with Big Dean. He would be able to help you further. Dave
135 Fan
10-22-2006 22:32:59
Need more info. Low hydraulic oil? Plugged filter? If it runs off 3 pt. pump the clutch has to be out at least first stage. Dave
