Installing a MF 232 loader on MF 231 tractor
Curtis P.
10-20-2006 05:28:40
I would like to know if I can tee the hydraulic lines for the loader into the existing auxiliary ports to make the loader operational. Thanks
135 Fan
10-22-2006 22:47:29
 Re: Installing a MF 232 loader on MF 231 tractor in reply to Curtis P., 10-20-2006 05:28:40
Yes, but if you only have one set of quick couplers, you need a seperate two spool valve for the loader. If you don't have any quick couplers you need a selector valve that goes on the hydraulic cover by the seat. My loader came with a two spool valve with float position on the lift. This is a much better control especially when back blading. Never go forward in float position though. Loader and 3 pt. can't be used at the same time. Dave
