mf165 multi power
pslick1
10-18-2006 08:56:12
Why does the manual suggest that you should leave the transmission in gear when the engine is shut off. I have a lot of hills and would like to rely on the engine as well as the brakes to hold the tractor when it is not operating. Just purchased this one.
Boss Hog
10-19-2006 06:34:53
 Re: mf165 multi power in reply to pslick1, 10-18-2006 08:56:12
If the tractor is pointed up hill when you stop it, yuo can leave it in a forward gear when you park it and it can"t roll backwards.
And the reverse is true - It can"t rool forwards when it"s parked and left in a reverse gear.
But when in doubt - Set the brake or block the wheels.
Big Dean
10-18-2006 09:57:37
To make it simple a tractor with a multipower transmission when the engine is shut off the pressure to close the multipower clutch pack will leak off in just a short time letting it go into low range the way the multipower transmission is designed it has no engine braking in low range so parking it in gear will not keep it from running away.
brianriver
10-18-2006 09:54:15
The multipower clutch pack is only applied when the engine is running the charge pump. It may hold for a few moments, but will leak down eventually. Only non multipower trannys will get you engine braking while not running. Make sure brakes are in good working condition and equally adjusted for optimal hill parking conditions.
