Massey 44 Special
Ken from Ontari
10-17-2006 18:11:36
I have a 1953 Massey Harris 44 Special S/N 44G1SF
50849.
On top of the air cleaner body, instead of the
normal stack and pre-cleaner, is a small assembly with a fruit jar on the side, as part of the assembly. I'm pretty sure Farmall use to have a set up like that, but when I check my parts book on the 44 Special, there is no plate showing this odd looking assembly. Was wondering if it was an
option put out by Massey on Western Specials only? I've never seen it on any other Specials.
It slides down tight on the air cleaner housing ok until it bottoms out and then the whole assembly seems loose and will not tighten up with
a regular clamp. This also makes me wonder if it is for this tractor or maybe someone has gotten it somewhere else and put it on.
Thanks in advance for any comments
Ian Johnsen
10-18-2006 19:48:03
 Re: Massey 44 Special in reply to Ken from Ontario, 10-17-2006 18:11:36
I can probably get you the original top or entire air cleaner if you'd like. I helped build a '54 44 special with a small block Chevy motor. The original stuff is laying around.
Ken from Ontario
10-19-2006 17:28:18
 Re: Massey 44 Special in reply to Ian Johnsen, 10-18-2006 19:48:03
Might be interested. Depends on where you are
located, please advise. By the way, what are you doing with the engine that was taken out of the tractor?
Thanks
msb
10-17-2006 21:18:45
Those dust collectors were from an off brand, short line manufacturer. Dad had one on a 1947 MH 44-6
Ken from Ontario
10-19-2006 17:20:13
 Re: Massey 44 Special in reply to msb, 10-17-2006 21:18:45
So what you are saying is it is not an original
OEM part.
msb
10-19-2006 20:01:19
 Re: Massey 44 Special in reply to Ken from Ontario, 10-19-2006 17:20:13
It is not an OEM part.It's possible it may have been made by Donaldson Company who made about all air cleaners for all tractors of the time and still do,I think, but I don't know.
